Vale?
Iniciado por LUW, 21 Julho 2009 às 10:25:25
LUW
Corvus Bradley Dive Watch
Citar
    *  WATER RESISTANCE: 1000 feet/300 meters. Double gasket caseback.
    * DIAL: Satellite Black™ coated. Our exclusive Satellite Black coating is the toughest, darkest coating commercially available, and was designed for use in satellites where extreme toughness and light absorption are essential. Much darker than other dial coatings, Satellite Black™ provides outstanding contrast with the dial markings and unsurpassed readability.
    * CRYSTAL: Double-domed AR coated (underside) sapphire, 3.5 mm thick
    * BEZEL: Unidirectional 60 click dive timer with luminous acrylic insert
    * LUMINOUS: White BG W9 SuperLuminova hour markers on the hands, and white C1 SuperLuminova on the dial and on the acrylic bezel insert. Hidden black stealth SuperLuminova minute markers on first 15 minutes of bezel insert.
    * CASE: Microblasted gunmetal-grey matt finish on 316L Stainless Steel, with surface case hardening to 1076 HV through the Kolsterizing™ process. This exclusive treatment provides exceptional scratch-resistance due to a surface hardness five times that of standard 316L stainless steel (200-240 HV). Precision fabricated by the master craftsmen at Fricker, Gmbh of Pforzheim Germany.
    * MOVEMENT: Swiss-made ETA 2824-2 automatic mechanical movement
    * DRILLED LUGS for easy strap changes
    * CROWN: Double gasket screw-down crown
Isso tudo por 1300 dinheiros
Acho que não.
[ ]s
Luciano
Se for em dólar/euro/libras: não vale.
Se for em real: vale.
Minha opinião, para o meu bolso, claro.
LUW
1300 dinheiros = 1300 dólares
1300 reais = 1300 merrecas ;D
E sendo sincero, mesmo que fosse 1300 reais não compraria.
[ ]s
Luciano
betampex
E um relogio muito bonito sem sombra de duvida, agora nao sei se pagaria este preco
Paulo
LUW
Se for para comprar um relógio de uma marca que não seja "mainstream", então eu preferiria este:
BaliHa'i Diver's Watch
CitarSwiss ETA 2824-2 Elabore Grade Automatic Mechanical Movement
316L Marine-Grade Stainless Steel Construction
120-Click Rotating Diver's Bezel
C-3 Superluminova
5.2mm Sapphire Crystal (Flat), AR Coated Underside
Helium Escape Valve (HEV)
Rated 1000m Water Resistant
44 mm Diameter (excluding crown)
52 mm Lug-to-Lug, 24 mm Strap / Lug Width
Stainless steel bracelet (solid link) with diver's safety clasp
Italian natural rubber ("NBR") strap with engraved buckle
Packaged in Pelican dive box
1 year limited warranty
Tudo isso por $795 ($895 pelo preto).
[ ]s
Luciano
Wadley
Achei Bonito e caro.
Trata-se de uma "homenagem"  ao Blancpain Fifty Fathoms.
Wadley
Clélio
Eu gostei tanto do Corvus como do BaliHa'i, mas não compraria nenhum...com este dinheiro compraria algum velhinho...talves um Certina DS3 ou um Eterna Diver ( será que dá ?? )
kinder
   Todos dois me alegraram, mas...........
              Essa grana é alta, vou ficar devendo !!!!!
      Abs, Kinder
Dos dois eu prefiro o balihai por uma semana, pela metade do preço então, por um mês, me agrada a história, o movimento, os detalhes e o preço, compraria com a pulseira de mergulho, a outra não combina...
Aliás, LUW, muito bem lembrado...
sat
Citação de: Clélio online 21 Julho 2009 às 19:37:37
Eterna Diver, eu não sei, mas Certina DS, dá e sobra.
SANDRO
Bruno Recchia
#11
Oi !
Olha, se for pra comprar um relogio tipo Fifty fathoms, eu pegaria esse aqui :
http://www.timefactors.com/precista.htm
O primeiro modelo da pagina, o PRECISTA PRS-50-B...
Por menos de 400 libras, o que deve dar em torno de 600/700 dolares, tem inclusive um movimento AS vintage, quase igual ao movimento utilizado nos Fifty Fathoms da época... Mas com resistência a 200 metros, ou seja, o dobro da resistência do original !
Bruno
Bela "dica", Bruno!
Muito legal, esse PRS-50-B. Além de ser um lndo relógio.
Grato por compartilhar o link!  8)
