Tag Heuer Monaco V4 Limited Edition Watch
Technical Specs of the watch straight from Tag Heuer:
TRANSMISSION
5 NOTCHED BELTS INCLUDING 2 WITH INTERNAL STEEL REINFORCEMENT WIRE
3 DIFFERENT TRANSMISSION BELTS, OF 0.25 X 0.07 mm, WITH A LOAD TO 130g
2 IDENTICAL BARREL BELTS, OF 0.5 X 0.15 mm, WITH A LOAD TO 1’300g
11 MICRO BALL-BEARINGS OF 2.2 TO 4 mm DIAMETER AND 0.6 TO 1 mm THICK
6 NOTCHED PULLEYS INCLUDING THE ESCAPEMENT PINION REPLACING THE TRADITIONAL PINIONS AND WHEELS
48 JEWELS
ENERGY
2 PAIRS OF BARRELS IN SERIES, SET IN PARALLEL AND INCLINED AT 13°, STORING 450g OF ENERGY EACH: 900g TOTAL STRENGTH
AUTOMATIC WINDING SYSTEM
LINEAR MASS WITH DOUBLE RACK RAIL: 12g TUNGSTEN INGOT
MOVEMENT FEATURES
28’800 VIBRATIONS PER HOUR
STRENGTH COLLECTING SYSTEM SET ON A MICRO BEARING AT 12 O’CLOCK
2 DISCHARGE RATCHETS WITH GEAR CUT AT 13°
ANNULAR BALANCE WITH 3 ARMS MADE OF GLUCYDUR
« TOP » QUALITY SWISS BALANCE-SPRING WITH MICRO BLAZED FINISHING
« RAQUETTERIE » WITH FINE ADJUSTMENT BY ECCENTRIC SCREW
52-HOUR POWER RESERVE
AVERAGE ACCURACY PER 24H: +/- 4 SEC
RANGE max 310°, min 210°
SMALL SECOND AT 4
WATCH FEATURES
PLATINUM 950 CASE
BEVELED EDGE AND CURVED SAPPHIRE GLASS
HAND-SEWN BLUE ALLIGATOR STRAP
FOLDING BUCKLE WITH DOUBLE SAFETY PUSH-BUTTONS IN PLATINUM 950
