A. Lange & Sohne - Flieger - FI 23883 - Luftwaffe
  • 58 Respostas
  • 17430 Visualizações
« Online: 12 Março 2010 às 12:04:11 »
Olá amigos,
Depois de anos, decidi requisitar um certificado de originalidade deste A. Lange & Sohne Flieger FI 23883.
O serviço da A. Lange é simplesmente inenarrável, nota 10 com louvor :-* :-*, diferentemente da Vacheron, e mesmo da Patek (isso é história para outra oportunidade)
Diferentemente de alguns outros relógios militares, como Omega, Cyma, Record, etc......onde nem todos iam para o front, ou seja, ficavam na intendência, por vezes, nem um único tiro escutavam ;D, estes modelos  iam mesmo para as batalhas aéreas (muitos se perderam, por motivos óbvios)..............não eram produzidos para ficarem na administração.
Aí estão as imagens, bem como o texto do especialista alemão Konrad Knirin sobre estes modelos!
Notem que o número de série do relógio está por todo o canto!
Espero que gostem
Description:
Avigation Wrist Watches of the Reichsluftwaffe:  A. Lange & Sons (Glashuette) Caliber 48.1
Lange adapted their 48.l calibre watch as a Fliegeruhr, an airman's watch. It had centre seconds, a black dial with luminous hands and figures, it did not have the up and down dial. It wound at 3 o'clock. The movement had 17 jewels and a larger balance wheel, 22mm in diameter, in nickel-steel. It had the swan-neck regulator. The case was 55 mm in diameter. A heavy leather strap was designed to be worn over a flying suit. They were regulated as navigation chronometers and tested, piece-by-piece, by the chronometer department in Gesundbrunnen near Glashuette. They had two different dials: normal hour hands and minute hands, or a small hour dial and a big minute dial. They were classified with 'FL 23883'. The FL stands for flight and the first two digits, 22, for flight control; 23 stands for navigation and 25 for radio surveillance. The equipment number was 127-560B (or A). As Lange ciould supply enough watches, these were mounted by other makers like Huber in Munich, Felsing in Berlin, Schieron in Stuttgart, Schaetzle und Tschudin in Pforzheim and Wempe in Hamburg and less known Metall-Lago in Vienna.
Application:
The demand from the Luftwaffe for accurate navigation watches was very great.  The magnitude of the enterprise can be judged from the numbers made. Deck watches and Deck chronometers, 1941 to 1945, 200001 to 205445. Fliegeruhr, with centre seconds, 1941 to 1945, 210,001 to 216,980. The number of the calibre 43 watches made is not known. There were three Fliegeruhr of a different design. They had a dial with an outer ring of numbers to show minutes or seconds and a small inner ring of numbers to show hours. The centre second hand and the minute hand were of the same length, the hour hand was short to fit the inner, hours dial. The dials were black, the figures and hands were luminous.
Walter Storz of Pforzheim made a Fliegeruhr to this design with an 18 ligne Swiss bridge movement  by Unitas. Lacher & Co. also of Pforzheim made a 22 jewel 22 ligne Fliegeruhr with a Deutsche Uhren-Rohwerke Glashütte movement. Gerhard D. Wempe had a 19 ligne Thommen Calibre 31 Swiss bridge movement in his Fliegeruhr. International Watch Co. of Schaffhausen delivered an 18 ligne watch which had an inner case of soft iron as a protection against magnetic fields in the cockpit
comparando
This watch is for historic/collector purposes only, and is not intended in any way to glorify, nor exploit the horrors and atrocities of war ;)
Re: A. Lange & Sohne - Flieger - FI 23883 - Luftwaffe
« Resposta #1 Online: 12 Março 2010 às 12:21:29 »
Parabéns, à Lange, à Glashutte pelo serviço e principalmente ao Gravina, pelo belo relógio e compartilhar as histórias...
« Resposta #2 Online: 12 Março 2010 às 12:28:18 »
Que maravilha!   :o
A história dessa peça deve ser algo absurdamente lindo.
Parabéns!
Offline shun
  • 2.411
« Resposta #3 Online: 12 Março 2010 às 12:37:55 »
Fantastico Gravina, você possui informações do dono original?
um abraço!
« Resposta #4 Online: 12 Março 2010 às 12:48:11 »
O Rolex ficou murchinho...
Parabéns pelo relógio. Lindo!
« Resposta #5 Online: 12 Março 2010 às 13:00:43 »
Mestre.
Simplesmente parabens, lindissima peça!
What the next step ?
« Resposta #6 Online: 12 Março 2010 às 13:04:01 »
Parabéns Gravina....Me emociona saber que uma raridade dessas está em suas mãos, uma pessoa que tem História dentro da horologia....abração grande... :D :D
« Resposta #7 Online: 12 Março 2010 às 13:04:55 »
 :o :o :o
Históricos!
A peça, sua história  e a postagem!
Grato por compartilhar, Douglas!  8)
« Resposta #8 Online: 12 Março 2010 às 13:47:29 »
M A R A V I L H O S O ! ! !
Offline FSV
  • 459
« Resposta #9 Online: 12 Março 2010 às 14:03:38 »
Prezados :
Ainda que toda peça tenha sua história - de aquisição, fabricação, disponibilidade no mercado etc. - esta faz parte da História, "aquela" mesmo, com "H" maiúsculo !!!
Sensacional !!!!!  ;) :D
Parabéns Mestre !!  :)
Grande abraço, Flávio.
Offline
  • 1.255
« Resposta #10 Online: 12 Março 2010 às 14:32:32 »
Pelo visto descobriram na Mooca um descendente direto do Barão Vermelho!!!!
Mesmo sendo este um personagem da 1ª Grande Guerra e o relógio da 2ª, tenho certeza que, se houver alguem por aí capaz de arranjar, realmente, um exemplar usado pelo famoso barão, este relógio fatalmente irá parar na zona leste de São Paulo...
Mestre, conte a história desta belissíma peça!
Forte abraço!
Offline leon
  • 815
« Resposta #11 Online: 12 Março 2010 às 15:38:41 »
 ;D ;D ;D SIMPLESMENTE FABULOSO ;D ;D ;D
« Resposta #12 Online: 12 Março 2010 às 15:43:07 »
Obrigado Fernando  :D
Putz!!! falha nossa!...................isso mesmo, meus agradecimentos extensivos ao Museu Glashutte :-* :-* :-*..................a cada nova mão que passava este processo, eu era comunicado via e-mail da atual situação"................coisa do outro mundo!!! :-* :-*
Ah!!!..em um destes tópicos recentes, você citou uma frase do criador do James Bond..................sobre aquela coisa de usar um Rolex.......tal, tal, tal
Definitivamente, Mr. Ian Fleming, não conheceu o Nicolas ;D.............este libanês também é do outro mundo ;)
« Resposta #13 Online: 12 Março 2010 às 15:44:11 »
Que maravilha!   :o
Parabéns!
Obrigado Sandro!! :D
« Resposta #14 Online: 12 Março 2010 às 15:47:57 »
um abraço!
Muito obrigado Shun!
Infelizmente não tenho...............só do dono anterior, que é o nosso amigo Marcos O. Arend (conhecido de muitos por aqui)..........um especialísta neste tipo de relógio!.......... e em outros também!.......o bom amigo!
Offline Wadley
  • 1.369
« Resposta #15 Online: 12 Março 2010 às 15:48:27 »
Show de bola !!!!
Wadley
« Resposta #16 Online: 12 Março 2010 às 15:49:09 »
Bota murchinho nisso ;D
Obrigado Humberto!!
« Resposta #17 Online: 12 Março 2010 às 15:50:17 »
Mestre.
Valeu Fabricio, brigadão!!!! ;D
« Resposta #18 Online: 12 Março 2010 às 15:51:19 »
Opa!!!.........muito obrigado Rodrigues!!
Valeu mesmo!!!
« Resposta #19 Online: 12 Março 2010 às 15:52:18 »
:o :o :o
Históricos!
Valeu Alberto!!!
Um bração
