Scuderia Spider edição limitada,...
e o seu respectivo adorno de pulso,...
Scuderia 1/8th Second Limited Edition
características dos brinquedos,...respectivamente
Ferrari Scuderia Spider 16M Technical Specifications:Engine
Naturally aspirated mid-rear 90° V8, 4308 cc
Maximum power output 375.4 kW (510 hp) at 8500 rpm
Maximum torque 470 Nm (47.7 Kgm) at 5250 rpm
Max engine speed 8640 rpm (at limiter)
Compression ratio 11.9:1
Bore and Stroke 92 mm X 81 mm
Specific power output 118.4 hp/litre
Transmission
Six-speed plus Reverse F1 gearbox
Dry dual clutch
Electronic differential E-diff + F1-Trac
Oil gearbox lubrication with oil/water heat exchanger
Performance, fuel consumption, emissions
Acceleration 0-100 km/h 3.7 s
Maximum speed 315 kph
Drive weight/power 2.6 kg/hp
Fuel consumption 15.7 l/100 km (combined ECE)
CO2 emissions 360 g/km (combined ECE)
Chassis and bodywork
Car dimensions:
- Length 4512 mm
- Width 1923 mm
- Height 1216 mm
- Wheelbase 2600 mm
- Front track 1669 mm
- Rear track 1616 mm
Dry weight * 1340 kg (-80 kg vs F430 Spider)
Kerb weight * 1440 kg
Weight distribution 43% front, 57% rear
Fuel tank capacity 95 litres
Independent front and rear forged aluminium double wishbone suspensions, titanium helical springs, hollow anti-roll bars and lighter electronic shocks
398mm X 36mm carbon-ceramic material front brake discs with aluminium 6-pot callipers
350mm X 34mm carbon-ceramic material rear disc brakes with aluminium 6-pot callipers
19" five-spoke split rims front and rear
Tyres: 235/35 front and 285/35 rear; Fabbrica Pirelli PZero Corsa only
Electronic control systems
CST Stability and Traction Control System. Steering wheel-mounted manettino with five settings to integrate the F1 gearbox, CST and F1-Trac (Stability and Traction Control System), suspension control. *Figures refer to the European market versions
___________________________________________________________
Scuderia 1/8th Second Limited EditionMovement
automatic mechanical,
Panerai OP XXI calibre, 13 ¼ lignes, 42 jewels. Monometallic Glucydur® balance, 28,800 alternations/hour. Incabloc® anti-shock device. Power reserve 42 hours, Côtes de Genève decorations on the bridges. Rotor engraved with the prancing horse.
Functions
hours, minutes, split-seconds chronograph with two counters, one with hand rotating once per second in 1/8 second increments, tachymeter scale.
Case
diameter 45 mm, in polished steel with brushed edges, screw-down chronograph push-pieces and winding crown with the Ferrari logo and rims worked with square-grid pattern.
Bezel
brushed steel with brushed finish.
Back
steel, screw-in, with sapphire crystal window decorated with a metallic grid; round the edge is engraved the inscription Engineered by OFFICINE PANERAI.
Dial
black with the Ferrari shield applied at 12 o'clock, 60-minute scale with Arabic numerals at 5-minute intervals, tachymeter scale on the flange, minutes counter at 3 o'clock and 1/8th second dial at 9 o'clock with applied cone-section rings in metal, chronograph split-seconds at the centre. 1/8th second dial, minute counter and centre chronograph seconds hand in yellow, luminous baton hour and minute hands.
Crystal
sapphire, 1.9 mm thick. Anti-reflective coating.
Water resistance
100 metres.
Strap
rubber strap with the incised inscription Ferrari, personalised folding buckle in brushed steel with the edge of the closure in polished steel. Spare strap in black calf with contrasting stitching, inside part in yellow caiman with yellow sewing.
Bracelet
