Technical Specifications:
CARBON FIBRE / TITANIUM / PVD CHRONOGRAPH - 7810 BSF 05207
Movement
Mechanical chronograph, ETA 7753 tri-compax,
28 800 vibrations per hour, automatic self-winding, 46 hours power-reserve, 27 jewels,
Functions
Chronograph
start, stop & re-start by push-piece at 2 o'clock
back to zero by push-piece at 4 o'clock
central chronograph hand
30-minute subdial at 3 o'clock
12-hour subdial at 6 o'clock
60-second subdial at 9 o'clock
date Round window at 4:30, push-button date-set at 10
Case
Round - titanium & polished/ brushed steel with black coating & lateral carbon fibre inserts, Diameter 46mm, Thickness 15.5mm, Length 55.1mm
Bezel
Upper: circular, brushed titanium with black coating & tachometer
Exterior: polished steel with 'godron décor' between brushed vertical bands, black coating
Crown
Steel - fluted, screwed-down - with adjustable RW monogram
Brushed titanium protection system with black coating
Push-pieces
Steel - fluted, screwed-down - black coating
Crystal
Sapphire crystal with double-sided anti-glare treatment, 2.5mm thick
Dial
Black
Central zone in relief, struck into dial plate
3 applique screws matching those to the case sides
indexes 11 applique indexes with luminescent anthracite highlights; matt applique figure 12
Hands
Hour/ Minute Boston diamond-tipped hands with luminescent anthracite highlights
Subdials Boston hands, blued steel
Small seconds Black Boston hand
Chronograph Bâton hand with counterpoise, blued steel
Case-back
Black titanium, screwed-down with RW monogram in relief
Bracelet
Saddle-stitched black crocodylus niloticus strap, RW folding clasp in black titanium, with double push-piece security
Water-resistance
20 ATM (200m/ 660ft)
