Esta marca junto com a Seiko acho que são as minhas preferidas pela qualidade conjugada com preço honesto
Agora vamos la,..
Technical Specifications:
Material: Stainless steel
Dial Color: Black
Attachments: Brown leather/black leather with carbon-fiber/black rubber/steel
Movement: Automatic 7750
Crystal: Sapphire
Water resistance: 100 m
Price: Ca 1245 €, 1645 USD, 1895 CHF
Launch: June 2009
Special Function: Mach Number calculator
International Standard Atmosphere (ISA) is an atmospheric model of how the pressure, temperature, density and viscosity of the earth's atmosphere change over a wide range of altitudes. It consists of tables of values at various altitudes.
Calibrated Airspeed (CAS) is a measure of the speed at which an aircraft is moving through the air.
Pressure Altitude (PA) is the indicated altitude when an altimeter is set to an agreed baseline pressure setting. This setting - 101,325 Pa, equivalent to 1013.25 millibar (or hectopascals), or 29.92 inches Hg - is equivalent to the air pressure at Mean Sea Level (MSL) in the ISA.
Mach Number (Ma or M) is the speed of an object moving through air, or any fluid substance, divided by the speed of sound as it is in that substance. It is commonly used to represent an object's speed, when it is travelling at (or at multiples of) the speed of sound. Mach 1.0 is the speed of sound, Mach 2 is twice the speed of sound etc.
Khaki X-Mach by HAMILTON
